Scan&Tioune Does not Start
Messagede on7ma » Mer 23 Nov 2022 17:06
Hello
When I start Scan&Tioune, it will not start..
the white banner says
"Minitiouner Pro-V2 detected with NIM Serit FTS-433x, Pse wait 5sec....."
Then nothing..
This banner keeps on the screen and nothing happens
I have to use TaskManager, to get it closed
I'm running W10-x64 on a i5 Computer
Minitioune 9.9.1j, runs perfectly, also TSAv0.9
Minitioune 1.0.1 has the same effect... white banner and blocks
Any idea's ?
Tnx JP, ON7MA
on7ma
Re: Scan&Tioune Does not Start
Messagede F6DZP » Sam 26 Nov 2022 06:36
I suppose that you have installed VLC 32 bits
Messagede on7ma » Sam 26 Nov 2022 15:55
Jean Pierre
I installed the VLC64Bits on my 64Bit System
Do I need to use VCL32 bits ?
JP ( JeanPierre aussi :-) )
on7ma
Messagede on7ma » Sam 26 Nov 2022 16:12
Installed VLC 32 Bits and evrything works now..
Tnx JP
on7ma
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 14 invités
