you are not on the frequency.
if we read the Freq --> value, we can see that the freq set is
10 710 470 kHzit should be 10 491 500 kHz (freq asked)
so you are at about 220 MHz far from the frequency searched. So it is normal that you receive nothing
now I try to know why you have this result... the derotator cannot go so far from the freq asked.
it seems that your MiniTiouner clock is bad (quartz?)
1) could you try to set the Derotator Symbolrate detection mode to 'scan'
2)Could you try to use the original minitiouneConfig.ini ?
3) using Minitioune, could you do CTRL +A and capture the new pannel
Jean-Pierre F6DZP[/quote]
Hello JP,
Thanks for your reply.
I do not know what has happened.
I can only say the this happened after i have fixed the board and all the LEDs in the box.
Here are the result of your requests:
1) Please how to set the Derotator Symbolrate detection mode to 'scan'? If i click on the Derotator Search tab,
i just see the Freq --> moving some kHz each time i click on it.
2) I have tried to download the program again and used the one just downloaded so with the original minitiouneConfig.ini file with the same results
3) doing CTRL +A while using Minitioune i get this:
- New Panel.png (222.23 Kio) Vu 93309 fois
Please what to do?
JP i have also noticed that when i switch on the minitiouner i have the RF Power to -100:
- Just switch ON.png (214.75 Kio) Vu 93299 fois
but if i just switch, in the program, the Fplug from "A" to "B" and then back to "A", so the RF Power jumps to -50:
- Switching A to B and back to A.png (215.64 Kio) Vu 93299 fois
Thanks for your helps
73's de Enzo IK8OZV
I edit the post as i have discovered the cause of the problem (
Thanks to Heiner DK0KP )
I have found the faulty it seems to be the Display but not quite sure if the problem is the display or the Minitiouner.
I have noticed that when the displayit is connected i get the problem when i disconnect it i get the signal back.
I have then tried to connect the display one pin at time making the test on each connected pin and have noticed that when i connect
the DATA PIN of the display to the SDA of the Minitiouner Pro2 Connector JP3, i get the problem if i disconnect just the DATA PIN of the
display to the SDA of the Minitiouner Pro2 Connector JP3, the problem does not come out anymore but the display does not show me any info
Please any help?
Thanks
73's de Enzo IK8OZV
PC= I9 / Win10-64bits.
IK8OZV
