TSA and Scan&Tioune LNB power supply with RT5047
Messagede oe8jpq » Mar 5 Jan 2021 15:20
I've a MiniTiouner V2 (BATC version) with a connected RT5047 board. How do i enable the LNB supply checkboxes on TSA and Scan&Tioune? I can't find anything in the ini.
Also i'd like to ask if it is possible to add a hardcode option to the ftdi chip, so i don't have to set it every time i install the software <- might be an idea for future releases if it is possible.
73 de Phil
OE8JPQ
oe8jpq
Re: TSA and Scan&Tioune LNB power supply with RT5047
Messagede F6DZP » Mar 5 Jan 2021 21:00
Just look at your minitiouneConfig.ini
there is the solution:
[MiniTiounerV2]
; si vous avez ajouté un module avec le chip de gestion LNB RT5047 / if you have added a RT5047 module for LNB 13v 18v
; V2LNBmodule yes or no
V2LNBmodule= yes
Messagede oe8jpq » Mar 5 Jan 2021 21:57
Dear Jean-Pierre,
Thank you! That worked for Scan&Tioune but still no luck with TSA
and btw what is a stecrtrum analyzer? :D typo above the scanner with the blue letters
73 Phil
OE8JPQ
oe8jpq
