Minitiouner v2 failing all tests.
Postby G8EEY » Wed 26 Feb 2020 16:04
I have just built a Minitiouner v2 using board, NIM and USB minimodule from BATC, 10K resistor added to USB module. All voltages are within spec and current is around 300mA.
I allowed a windows 10 laptop to setup usb drivers and powered up the Minitiouner. Running TestMyMinitiouner (latest) fails completely. Am I looking for hardware or software failure?
Mini Test gives:
D2XX test -OK Device Present... NIM : ?????
___________________________________________
DLL version: 3.2.14
we have found 2 device (s)
device 0:
device named: FT2232H MiniModule A
device 1:
device named: FT2232H MiniModule B
>>>>>>>>>> NO MiniTiouner connected to USB MASTER!
>>>>>>>>>> NO MiniTiouner-Pro connected to USB AUX!
_________________________________________________
________
G8EEY
Re: Minitiouner v2 failing all tests.
Postby G8EEY » Sat 29 Feb 2020 16:25
Problem solved, the BATC supplied FT2232H usb mini module did not seem to be pre-programmed as expected.
Mike.
G8EEY
Return to Minitioune
