Tioune Monitor
Postby liby » Sun 13 Oct 2019 08:55
Why don't I see my name on the Tioune Monitor list ?? ...
(the web button on MiniTiouner is activated).
liby
Re: Tioune Monitor
Postby F6DZP » Sun 13 Oct 2019 15:46
it works automatically, just by pressing the Web button, the first time your icon is created on the map and yoou are added on the list.
perhaps you forgot to put your Password that you use for the viavadatv forum in the minitiouneConfig.ini
Re: Tioune Monitor
Postby G8YTZ » Tue 15 Oct 2019 06:29
Hi Jean-Pierre,
I can see myself on the list, but not the map. Somewhere I have a configuration wrong, could you advise me?
Also is it possible to display H264 video on the TiouneMonitor?
best regards,
Justin.
G8YTZ
Re: Tioune Monitor
Postby F6DZP » Tue 15 Oct 2019 11:21
Your Icon uses the QRAlocator you have put in the minitiouneConfig.ini
perhaps it is under another icon from another OM that has the same QRAlocator?
try to receive something and send data to the Tioune Monitor, you will see your icon jumping...
The web monitor receives only screenshot of the video ( 1 per second if you set it)
Re: Tioune Monitor
Postby G8YTZ » Tue 15 Oct 2019 17:19
Many thanks Jean-Pierre,
Finger trouble - I had my video monitor off and I had put the locator in with two Zeros when one should be an O!
best regards,
Justin.
G8YTZ
Return to Minitioune
