Each time I tune a video feed now it crashes ?
Postby m1ctk » Tue 8 Oct 2019 22:56
All of sudden tonight every time I try a feed my minitiouner software crashes. Anyone else had this ? If I leave it on the beacon it's fine though. Can't understand why as this has never happened before
m1ctk
Re: Each time I tune a video feed now it crashes ?
Postby F6DZP » Wed 9 Oct 2019 04:02
if you receive the Beacon without problem you don't have hardware problem
Beacon codec is H264.
H264 can be decoded by the Windows Video decoder or LAV video Decoder
I suppose you have problem with H265 codec
H265 cannot be decoded by Windows video decoder, only by LAV video decoder
try to re install LAVfilters.
I need more information to go farther.
try
- force Minitioune for not decoding, just receiving the TS. For that let the AutoPID button Off and write PID video and audio at 65535 before receiving a station (or any value that is not the PIds of the station).
So when you are locked and not decoding because you don't have the PIDs, does Minitioune crash?
I suppose not.
now swith the AutoPID button to ON
can you read the codec detected and observe more things when it crashes?
Postby m1ctk » Wed 9 Oct 2019 08:13
I reinstalled the Lav filters now I don't even get video with the beacon in fact no signal even now, it's totally bizarre...
m1ctk
Postby m1ctk » Wed 9 Oct 2019 11:27
Now working fine, don't know why. Thanks for response
m1ctk
Postby F6DZP » Thu 10 Oct 2019 03:58
I can't help you, you don't give me information as I asked.
Postby m1ctk » Fri 11 Oct 2019 01:11
F6DZP wrote:I can't help you, you don't give me information as I asked.
It's ok thanks now all working, if it happens again I will give the needed information you want
m1ctk
Return to Minitioune
