Could not use the universal Source Filter
Messagede 9H1GB » Dim 16 Sep 2018 08:54
As I have stated in another post here on the forum I received the MiniTioune unit.
I installed software version V0.8s and when I run the program I get the first message
MiniTiouner-Express with NIM Serit FTS4334 Deteched
MiniTiouner Schematic: www. Vivadatv.org)
Please Wait 10 sec, Minitiouner V0.8 is loading...
Soon after I get this Second message
and if I do not click on OK the program will not run.
Any ideas of what could be the problem please
Regards
Mans. 9H1GB[url][/url]
9H1GB
Re: Could not use the universal Source Filter
Messagede F6DZP » Lun 17 Sep 2018 07:45
You have not installed the usrc.ax Directshow filter
1) read the readme.txt file
2) begin by testing your installation with "CheckMiniTiouneDriverAndFilters"
Messagede 9H1GB » Ven 21 Sep 2018 15:26
Hi Jean-Pierre,
Thanks for the info and Help.
Yes what you suggested solved the problem.
If I may, I am trying to stream on the web map but no luck.
I am trying to change my username to 9H1GB by deleting the current account and create a new account as 9H1GB but keeps reporting email address is already in use.
How Can I contact the Administrator maybe he can change the username for me.
I think that is why I cannot see myself on the Web tutioune.php?what=map#
Thank you for any help and or assistance
Mans. 9H1GB
9H1GB
Messagede F6DZP » Dim 23 Sep 2018 11:38
I have change your user name by : 9H1GB
You can login now using this name.
If you want to see yourself on the TiouneMonitor, you need to write your call and your password in the minitioune.ini file. After you have just to press the WEB button on Minitioune and your icon will be automatically created on the map.
Messagede 9H1GB » Dim 23 Sep 2018 21:55
Hi Jean-Pierre.
Thanks .
Login ok
Mans. 9H1GB
9H1GB
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 19 invités
