Scan/spectrum function
Messagede 4Z1ZV » Ven 22 Nov 2019 15:21
Just got, installed and used my new MiniTiounerPro.
Nice product, great software.
Just wonder if there if there is a tool or functionality to display the spectrum, so I do not have to relay on webSDR.
Thanks
Zvika 4Z1ZV
4Z1ZV
Re: Scan/spectrum function
Messagede F6DZP » Ven 22 Nov 2019 19:35
yes, Tiny Spectrum Analyzer (TSA) I 'm working on it every day and hope to offer it for download soon.
look at https://www.youtube.com/watch?v=51Sid2Jkulo&t=28s
and
https://www.youtube.com/watch?v=LLzk6gdkDGg&t=31s
Messagede 4Z1ZV » Mer 25 Déc 2019 09:06
I installed today the QO100 Live Tune.
It does show the spectrum and sends parameters (I see them on the expert screen).
However the software start searching but do not lock.
I played with the offset - no impact.
Using the Pro2 and V9.0.
Zvika 4Z1ZV
4Z1ZV
Messagede DL4OCH » Mer 25 Déc 2019 21:37
You need to use the APID-switch (top right) manually. Otherwise it will try to lock with the parameters from the last stream.
Then it works excellent.
vy73 de Wilm,
DL4OCH
DL4OCH
Messagede 4Z1ZV » Dim 29 Déc 2019 10:26
OK. Need to set the LNB to 18V.
Now it works just GREAT.
Zvika 4Z1ZV
4Z1ZV
Messagede lancer21 » Dim 29 Déc 2019 17:31
Thanks for recommending the QO100, I've looked a little bit into that and itlooks like it's precisely what I was looking for!
lancer21
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 23 invités
