Display connection
Postby G8NOP » Fri 26 Jul 2019 21:39
HI,
I now have a 2.6" Serial:UART/I2C/SPI IPS Super TFT LCD 320x240 display.
As it arrived with no spec sheet I would appreciate a photo of its connections to the MinitiounerPro V2 board. I gather that in one of the photos on the forum the connections are shown incorrectly.
Pip G8NOP
G8NOP
Re: Display connection
Postby sm4ive » Mon 5 Aug 2019 07:04
Hi on the display you have to make an solder bridge betwen iC2 dots
on Minitiouner pcb there are several sockets you can use i use the one on the side of Tuner. Look at the socket its printed
GND,VCC,SDA,SCL you will se the same on the display
on display VCC, SDA,SCL, GND simple as that GLhttp://www.digole.com/index.php?productID=1271
sm4ive
Postby G8NOP » Mon 5 Aug 2019 10:17
Thanks for the advice SM4IVE. I'll progress now and hopefully connect up later today.
G8NOP
Postby ik8ozv » Tue 12 Nov 2019 15:48
sm4ive wrote:Hi on the display you have to make an solder bridge betwen iC2 dots
Please can you tell me the right connection?
I have connected like this:
The VCC of the display to the VCC of the Minitiouner Pro2 Connector JP3
The DATA of the display to the SDA of the Minitiouner Pro2 Connector JP3
The TC/CLK of the display to the SCL of the Minitiouner Pro2 Connector JP3
The GND of the display to the GND of the Minitiouner Pro2 Connector JP3
i have made the bridge from the middle Pad and the Pad named I2C.
When i power up the Minitiouner Pro2 i can see the Display changing colors from
white to orange then to green and finally to blue.
Then it remains black with a light of white and can read on the top:
I2C Address: 0x27 V4.1V+2MB Flash
Please what am i doing wrong?
Thanks
Enzo
PC= I9 / Win10-64bits.
IK8OZV
ik8ozv
Postby F6DZP » Wed 13 Nov 2019 06:33
Hi Enzo,
All is OK.
Your Digole LCD seems to be OK, it displays all it must show when starting.
It is well connected to JP3
Now you must test it using "TestMyMiniTiouner".
Postby ik8ozv » Wed 13 Nov 2019 10:27
Hello Jean-Pierre,
Thanks for your reply.
Please which is the procedure to test it
And what should I get?
Enzo
IK8OZV
ik8ozv
Postby sm4ive » Wed 13 Nov 2019 15:31
what do you see when you start the software? Minitiouner dispaly only starts when you start the software.
73 Lars SM4IVE
sm4ive
Postby ik8ozv » Wed 13 Nov 2019 15:47
I said before what i see.
Thanks
Enzo
IK8OZV
ik8ozv
Postby sm4ive » Wed 13 Nov 2019 19:50
ik8ozv wrote:I said before what i see.
Thanks
Enzo
YES but display only works when you start the Minitioune program Connect via usb to computer and start minitioune prgram then display works
sm4ive
Postby F6DZP » Wed 13 Nov 2019 20:08
You can test your disply using the software "TestMyMinTiouner"
Next
Return to MiniTiouner Pro
