3D Printer case for MiniTiounerPro V2
Messagede 4Z1ZV » Sam 23 Nov 2019 21:55
Uploaded today:
[url]QO-100 MiniTiounerPro V2 Case by 4Z1ZV - Thingiverse https://www.thingiverse.com/thing:3996213[/url]
Zvika 4Z1ZV
4Z1ZV
Re: 3D Printer case for MiniTiounerPro V2
Messagede f8buu » Dim 15 Déc 2019 16:20
Hello dear OM 4Z1ZV. I've just finished to print the case !
It s almost perfect, but I was forced to remove the two beads from the 2 holes of the NIM, otherwise the card did not fit in the case correctly.
I think this problem is due to type of NIM used.
If you have the possibility to remove theses 2 beads on each F plug (inside the panel), I think it could be ok for all NIMS.
Maybe there is enough space to add the lcd display ?
Thank you so much for this case, minitiouner pro is correctly protected !
Best regards
73 QRO F8BUU Patrice :D
f8buu
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 8 invités
