MT 1.0.1.0r with Samsung/Sharp tuner does not startup
Messagede PE1CVJ » Mer 16 Juin 2021 13:34
Dear Jean-Pierre,
First of all I like to express my great appreciation for all the new functionality you've put again in this Beta version 1.0.1.0r! Great job!!
When connecting to a Minitiouner-Express, Rev. B, it all works fine. When I however connecting to an old design Minitiouner containing Sharp/Samsung tuner, the application doesn't start properly and is hanging in the startup screen. It detects the MT hardware but the 5 sce waiting statement indicates the loading of V0.9 and that's it for an indefinite length of time. The old MT runs fine with the previous versions V0.9....
I expect it's caused by a missed link to the new situation hi! I haven't been able to (yet) check this cause by the old model MT or the specific tuner used... If necessary, I can arrange a test with an old model MT with Serit tuner.
My PC is running Windows 10Pro, latest updates and VLC 3.0.14 32bits.
Hope this is helpful feedback.
Kind regards,
Lex Peters
Pe1CVJ
73, Kind regards,
Lex Peters (PE1CVJ)
Amstelveen
The Netherlands
PE1CVJ
Re: MT 1.0.1.0r with Samsung/Sharp tuner does not startup
Messagede F6DZP » Dim 20 Juin 2021 05:57
The last beta version has not been yet tested/adapted to Sharp/eardatek NIM tuner.
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 22 invités
