Minitioune error shoe video and hang
Messagede nanrspm » Sam 15 Juin 2019 19:06
please seen as link you tube
https://youtu.be/adUiqb6QWUc
https://youtu.be/DRYfCDax8Cs
I 'm used MiniTiouner V2 PCB with component and MiniTioune software V0.8s and 0.9 beta for receive signal but problem have error on Minitioune software after install LAV filter and decode signal success.
computer Hang and not show video but use switch record for recoard and play back. please advice me for problem and repair software.
Regards.
Tanan Rangseeprom HS1JAN
Project Manager of JAISAT-1 satellites and Manager of HS0AJ Ground Station
nanrspm
Re: Minitioune error shoe video and hang
Messagede F6DZP » Dim 16 Juin 2019 19:05
This is not a problem with the software Minitioune, it receives your TS and can record it.
This is not a problem with the hardware as you can record the TS received.
This is a problem with your computer/Windows that cannot render the video using Directshow.
1)Test firstly with the software "CheckMiniTiouneDriverAndFilters_V0_5a"
2) test also if you can see the viedo using VLC via UDP
3) check the CPU% used ans see if the value is not to high when you try to render the vidéo.
Utilisateurs parcourant ce forum: Google [Bot] et 1 invité
