Test my Minitiouner v2.0a on V2
Postby G3UEQ » Tue 21 May 2019 11:45
My Minitiouner V2 rx is working fine, passes all the checks OK in filter tests etc.
Works OK on V0.8ss and V0.9beta. I had never run the TestMyMinitiouner software which I did today for curiositys sake and it failed.
I get this message:-
DLL version: 3.2.14
we have found 2 device(s)
device 0:
device named: MiniTiouner_Pro_TS2 A
For NIM I2C, we will use this device
FT2232H NIM_I2C is open
Handle: 7203248
device 1:
device named: MiniTiouner_Pro_TS2 B
For TS2, we will use this device
FT2232H FIFO open for TS2
Handle: 7202840
FT2232H FIFO closed for TS2
USB driver version: 2.12.28
>>>>>>>>>> NO MiniTiouner-Pro connected to USB AUX! <<<<<<<<<<<
I have fitted the resistor and it receives OK on both inputs.
Any ideas?
Andy G3UEQ
G3UEQ
Re: Test my Minitiouner v2.0a on V2
Postby F6DZP » Tue 21 May 2019 11:56
I don't understand what fails.
on what I see, all is normal, if you don't use a MiniTiounerPro, you don't have the second USB cable AUX.
Return to MiniTiouner
