Another little problem.
I'm trying to get the 22kHz TS lock signal to work as the same time as the video being decoded.
If I set TS=2 and 22khz_switch=2, I get video displayed but no 22KHz lock signal output
but if I set TS=1 then I get 22KHz lock signal but no video.
Any idea what I'm doing wrong ?
Also is there any way to set the screen format on power up ?
I'm building this rx for a repeater and would like it to boot up in non expert mode, full screen with just the status constellation info across the bottom.
73 Tim
Home
