Build your own USB tuner
Problem with FTS-4334LV
Messagede G6CRF » Mar 13 Juin 2017 22:22
Hi, I just exchanged the NIM on my board from the Eardetech to the FTS-4334LV using the BATC adapter board.
I upgraded to MiniTioune 6d using the new ini file and executable and started it up, but the software is reporting the NIM as an SP2246 and not the FTS.
Have I missed a configuration step somewhere?
Thanks
Terry
G6CRF
G6CRF
Re: Problem with FTS-4334LV
Messagede G6CRF » Mer 14 Juin 2017 20:21
Ok Brian G4EWJ solved the problem for me. I had omitted R101 from the circuit.
Now I have inserted it, everything works.
Regards
Terry
G6CRF
Messagede dj3dy » Ven 4 Aoû 2017 11:26
I built the new Minituner 2.1. But the programm Minitoune 0. 6.d is not working.
First I checked with the MiniTuneDrive, result: all LED are green. Now I running the M.06.d, programm is starting, but after about 2 minutes it will stop. Therfore I run the M.driver programm again and now I get a wirting error.
When I am using the former usb Minituner with the Samsung tuner, it will running without errors.
TestMyMiniTiouner has no error. After running M.0.6 this message:
****************** I2C controler INIT *******************
I2C controler INIT OK
OK MPSSE is empty
Init MPSSE I2C done!
NIM Test
Demodulator Address = $D0
we get the value = 198
ERROR : Unknown Demodulator
Demodulator Address = $D4
we get the value = 70
Demodulator Address = $D2
we get the value = 17
ERROR: impossible to read a correct value from Demod chip
END Test NIM
My PC: Windows 10 V 1703 systemtype 32 bit
the configuration file date 23.03.2017.
dj3dy
Messagede F6DZP » Sam 5 Aoû 2017 05:25
there are different possibilities:
- bad USB port or USB cable. if these are the same that you use with the Samsung NIM, I don't think it is this issue, but check the USB connection again, or try another USB plug in your PC
- bad contact with some pins of the NIM, specially the SDA and SCL pins(21 and 22) . Check also that pin 24 has 3.3v
- noise on the SDA /SCL lines or a too large capacitor has been put on these lines ( if we put a capacitor, it must be of few pF)
TestMyMinitiouner try to detect the NIM by asking values via I2C lines (SDA and SCL), it should have an answer only using $D2 address and You seems to have different answers so I presume that you have noise or bad contact on your I2C lines.
If you have a big capacitor on one of these lines, take it away, if you don't have any capacitor and are sure that the SDA/SCL contact are very good, try to add a little capacitor of 10 or 22 pF between these lines and the ground.
Messagede dj3dy » Sam 5 Aoû 2017 17:32
Hello Jean-Pierre,
thanks for your help and for your excellent program.
The NIM is now running and I received the DVB-S signal of DB0CD on 434 MHZ.
It will be the noise on the I2C lines. I put two capacitors 20pf between these lines to ground.
(Excuse my former NIM is not a Samsung, it is a Sharp)
vy73 Rudolf, DJ3DY
dj3dy
