Build your own USB tuner
Minitioune crash after last WIN10 update !
Messagede f1faq » Jeu 16 Mar 2017 21:17
ATTENTION !
Correction : as it is the english section of the subject !
Minitioune crashes after last Microsoft update for Win10 (launched this tuesday)
True for 32 and 64bis version !
Our colleagues from BATC discovered this today
Jean-Pierre F6DZP is aware, hope he will find a counter measure !
F1FAQ
La dernière mise à jour de Win10 (dispo depuis mardi) rend incompatible l'application Minitioune, qui s’arrête
peu après le lancement.
Que ce soit avec WIN10 32bits ou WIN10 64bits
A été découvert par nos collègues du BATC et je confirme chez moi sur deux de mes PC qui ont été mis à jour
Jean-Pierre est prévenu
F1FAQ
Re: Minitioune crash after last WIN10 update !
Messagede F6DZP » Lun 20 Mar 2017 11:02
after latest Windows 10 update (KB4013429), we cannot continue to use the Microsoft Mpeg2/H264 video decoder, so Minitioune ( or DVD player) will crash.
The solution is here:
http://batc.org.uk/forum/viewtopic.php?f=105&t=4872&p=12113#p12113
The bug is with the Microsoft Mpeg2/H264 decoder. The new file CompPkgSup.dll has a bug.
People that use LAV video decoder don't have this issue.
Messagede dj3dy » Jeu 23 Mar 2017 12:28
Sorry, I get the error: you have not the permission to change the dll. I used the fix-exe as administrator.
WHAT CAN i DO ?
dj3dy
Messagede F6DZP » Jeu 23 Mar 2017 17:24
If you cannot do it with the fix, you must do it "by hand"
you must change the right about the files "CompPkgSup.dll" inside /windows/syswow64 and inside /windows/system32
change the owner and tell that is the administrator.
After that the fix software should work.
Messagede dj3dy » Jeu 23 Mar 2017 19:18
Dear Jean-Pierre,
thank you for your help.
Windows10 told me today it is up to date. (I had automatic update)
Nevertheless I looked for an update and see for windows10 1607 is the update KB 4015438 available.
After the update your programms are running without crash.
vy 73 Rudolf,DJ3DY
dj3dy
