DATVRPI SD Image available for download
Messagede F5OEO » Jeu 27 Mar 2014 10:04
SD image in ready to download at least : http://f5oeo.fr/DATVRPI0.1.rar
hardware required :
Raspberry Rev B
PiCAM
Installation:
- On a PC under windows (for other OS use the guide described
Download the .rar at location above
Decompress the .rar archive (using winrar under windows for example)
You should have a SD physical port (usely included on laptop)
On windows : use http://sourceforge.net/projects/win32diskimager/ to write the file DATVRPI0.1.img on SD
Put SD card in the Raspberry
- On the Raspberry
login : pi
passwd : raspberry
Carefull, it seems that I let the azerty keyboard by default (french).
For english keyboard, it it doesnt work :
user : pi
passwd : rqspberry
For Digilite users : plug usb to digilite
login as: pi
pi@192.168.0.20's password:
Linux raspberrypi 3.10.33+ #658 PREEMPT Tue Mar 18 17:35:55 GMT 2014 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Mar 24 09:17:24 2014
pi@raspberrypi ~ $ cd DATVRelease/
pi@raspberrypi ~/DATVRelease $ ls
Digilite ffplay ffserver sendtoudp.sh tsudpsend
ffmpeg ffprobe HidesRelease tsudpreceive
pi@raspberrypi ~/DATVRelease $ cd Digilite/
pi@raspberrypi ~/DATVRelease/Digilite $ pi@raspberrypi ~ $./usbdigilite.sh
It should modulate with SR 2000/FEC1/2
If you want to edit the config :
nano usbdigilite.sh
That's really the beginning, hope that with collaboration people could document and experiment lot og stuffs
For Hides users :
pi@raspberrypi ~ $ cd HidesRelease
pi@raspberrypi ~ $ ./encohides.sh
73's Evariste F5OEO
F5OEO
Re: DATVRPI SD Image available for download
Messagede on4bhm » Lun 15 Sep 2014 16:44
I downloaded the rar file and tried it on my rasberry pi.
I'm using a hides tx only usb dongle.
the program starts ok, led of camera is on.
but after 100 frames it stops working.
with a mesage:
send() error: no such device.
on spectrum analyzer i see some transmissions for a while...
what could be the reason of this failure?
there is no usb hub between rasberry pi and hides dongle.
Could it be firmware related?
thanks for any advice....
ON4BHM
sysop ON0SNW
on4bhm
Messagede df3ei » Ven 17 Mai 2019 13:47
Hi, all,
is this image still somewhere? I have a few Hides dongles that I'd like to experiement with.
Thanks and 73,
Jörg
OE1AGF
df3ei
Messagede ON4AAH » Sam 18 Mai 2019 07:43
Hallo Evariste.
I tried to download the software but no contact with the server, maybe temporarily offline.
73's ON4AAH.
The requested URL /DATVRPI0.1.rar was not found on this server.
Apache/2.4.10 (Debian) Server at f5oeo.fr Port 80
ON4AAH
Messagede f1faq » Dim 19 Mai 2019 11:09
Hello ON4AAH
This software is very old now (2014 !)
If you have a Lime mini you should use DVBSDR from Evariste
Fluid video with Picam and audio in H264 !
See here : https://github.com/F5OEO/dvbsdr
F1FAQ
Messagede ON4AAH » Dim 19 Mai 2019 14:43
Thanks Christian for information.
I don't have a lime mini but three DigiLite transmitters, 13, 23 and 70cm, I'm looking for a way to make a stream with the raspberry pi to de DigiLite via the USB ports.
73's My best regards ON4AAH Albert
ON4AAH
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 13 invités
Retourner vers Rapsberry H264 DATV
