ScanAndTioTune Error
Messagede ik8ozv » Jeu 16 Avr 2020 20:14
please i need an help to run the ScanAndTiotune V.01p.
I am using Windows 10 64Bit and Despite having VLC installed in
C:\Program Files (x86)\VideoLAN\VLC\
i get the warning:
regEdit n'a pas trouvé la key; SOFTWARE\VideoLAN\VLC
Clicking on the OK Tab i get another warning:
si on la clé du registre, on trouve
Clicking on the OK Tab i get again another warning:
verify that you have VLC 32bits installed in "C:\Program
Files\VideoLAN\VLC" on a Windows_32 bits or "C:\Program
Files(x86)\VideoLAN\VLC" on a Windows_64 bits
Load vlc library failed
Clicking on the OK Tab, the progam exit.
Please what am i doing wrong?
Any help will be really appreciated
73's de Enzo IK8OZV
PC= I9 / Win10-64bits.
IK8OZV
ik8ozv
Re: ScanAndTioTune Error
Messagede F6DZP » Ven 17 Avr 2020 06:04
do you have the files libvlc.dll and libvlccore.dll in the directory C:\Program Files (x86)\VideoLAN\VLC\
do you have the last version of VLC 32 bits?
Messagede ik8ozv » Ven 17 Avr 2020 09:01
F6DZP a écrit:Hello,
Thanks Jean-Pierre.
Found the problem, had the 64Bit version instead of the 32Bit.
Uninstalled the 64Bit and installed the 32Bit and the program worked perfectly
73's de Enzo IK8OZV
IK8OZV
ik8ozv
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 56 invités
