Windows 10
Messagede mm0mgb » Mar 7 Mar 2017 12:11
Hi
I'm very new to this and have a TT S3200 card in my PC running windows 10. The card works fine with DVB Viewer but I'd like to be able to use Tutioune. I cannot get the SAA7146A driver to install so the software wont recognie the card. Is there any way to get Win10 to work with this? or should I give up! I dont now have a win7 machine so cant roll back.
Andrew MM0MGB
mm0mgb
Re: Windows 10
Messagede mm0mgb » Mer 8 Mar 2017 09:10
Cracked it!
Restart windows 10 holding down the shift key, it will take you to a menu giving boot options, set it to boot and accept unsigned drivers. heres the link https://www.maketecheasier.com/install- ... windows10/
I still couldnt get win10 to load the driver but it did let me update the existing BDA driver manually. ie specify where the desired driver is. All working beautifully!
Andrew
mm0mgb
Re: Windows 10
Messagede G1LPS » Ven 10 Mar 2017 13:57
thanks for sharing that one easier than previous methods
Terry (G1LPS, Durham)
G1LPS
Re: Windows 10
Messagede Matbee » Lun 2 Oct 2017 12:17
G1LPrS a écrit:thanks for showing people these amazing probiotics for women and that one easier than previous methods
Good solution. As long as you got it running, doesn't matter if you had to do it manually or not, right?
Sujet remonté par Matbee le Lun 2 Oct 2017 12:17.
Matbee
