How to install Saa7146a driver under Win8.1 64 bits
Postby PA1KW » Sun 4 May 2014 17:14
You have to disable driver signature enforcement in the advanced startup options, see this link:
http://community.spiceworks.com/how_to/ ... indows-8-1
73 Koert PA1KW
PA1KW
Re: How to install Saa7146a driver under Win8.1 64 bits
Postby PA1KW » Sun 8 Feb 2015 10:50
A permanent solution but less secure is to execute following commands:
bcdedit.exe -set loadoptions DISABLE_INTEGRITY_CHECKS
bcdedit.exe -set TESTSIGNING ON
It will show a watermark in the lower right corner with a message that you are running in test mode.
Use at own risk
73 Koert PA1KW
PA1KW
Users browsing this forum: Bing [Bot] and 1 guest
Return to TUTIOUNE: DATV/DVB-S Measurement and Display Software
