Version number incorect
Messagede G6ZVE » Sam 16 Nov 2013 15:14
Hi Jean Pierre,
I have downloaded and installed instal tutioune1600v0_3a_en.zip
from the website but when i run the program it says Version 0.2c in
the Header of the program,I am using a pci card TT S2-1600,
Is this correct or has the wrong version been put into the zip file ?
I look forward to your reply,
Best regards,
Ian G6ZVE.
P.S Thanks for your great software and all your hard work.
G6ZVE
