Which good Tuner cards for Tutioune?
Messagede F6DZP » Ven 11 Nov 2011 11:54
Tutioune need to be used with a card that has a STB0899 demodulator and SAA7146A interface chip
you must use one of these PCI cards:
-TechnoTrend TT S2-3200
-Skystar HD ( not HD2)
-KNC One HD
-Mystique Satix DVB-S2
-Satelco EasyWatch HDTVS2 PCI
they all have an STB0899 demodulator and SAA7146A interface chip
73 de Jean Pierre F6DZP
Re: Which good Tuner cards for Tutioune?
Messagede ON6JM » Jeu 8 Déc 2011 08:41
I am looking for an external USB connected tunercard
any brand - type that can be used for Tutioune ?
In this way the laptop can be sued as a "search and find" instrument
tks in advance
ON6JM
Messagede F6DZP » Jeu 8 Déc 2011 11:12
Yes I know that would be a good new upgrade to use USB cards.
For the moment Tutioune works only with PCI tuners with STB0899 chip.
I hope to add this winter the possibilty to use USB driver for USB tuner using same STB0899 like TT S2-3600 or TT S2-3650.
Messagede ON6JM » Ven 27 Avr 2012 06:31
Tks for the info
any update re USB tuner compatibility ?
tks in advance 73s de joel
ON6JM
Messagede ON6JM » Jeu 18 Oct 2012 10:54
Merci pour les infos.
J'ai un autre demande concernant D-ATV venant de la UBA - section ARISS....
Veuilez me contacter en direct pour plus de details svp via ON6JM@telenet.be
merci d'avance.
ON6JM
