Emission 25Ks to 2Ms: GENERATE FLUX IPTV with OBS + FFMPEG +
Messagede F1EJP » Mer 24 Fév 2021 13:22
Emission 25Ks to 2Ms: GENERATE FLUX IPTV with OBS + FFMPEG + NVIDIA card + Script
> Step by step explanation (Tested on Portsdown)
You have to "search" everywhere on the NET to find the explanations and make the choice of software and equipment to use for the DATV program. I wanted to summarize here for you a little explanatory tutorial to generate an MPEGTS stream usable with Portsdown and LimeSDR mini but also any broadcast channel accepting an IPTV input: Express DVB Transmiter or Plutot (not tested)
Here is a first version of script successfully tested on Portsdown with LimeSDR mini
Inspired by the scripts found on the BACT Forum I created this script to generate a TSMPEG stream in H264 or H265 for the different types of BVBS DVBS2 modulation in 4, 8, 16, 32 PSK
For this, I bought a Graphics card for my NVIDIA GTX 1660 pc
FFMPEG can use GPU processors from NVIDIA cards to compress to H264 and H265
I have not been able to test with other models, please give me your feedback during your testing.
traduction from this forum
see attached
ffmpeg.zip
(71.15 Mio) Téléchargé 24792 fois
IPTV-F1EJP-OBS.zip
(3.41 Kio) Téléchargé 24103 fois
Emission 25Ks to 2Ms English.pdf
(626.08 Kio) Téléchargé 27335 fois
Re: Emission 25Ks to 2Ms: GENERATE FLUX IPTV with OBS + FFMP
Messagede G7JTT » Mer 24 Fév 2021 18:49
Excellent work seems to be work very well on all the common modes I use and those I haven't managed to get to work. My setup is a Portsdown 2020 with a I5 laptop with a RTX2060 video card.
The only edit I have made is to add the line "taskkill /F /IM ffmpeg.exe" just after the pause before ffmpeg starts,
Code: Tout sélectionner
:CODAGE
pause
if %COD%==1 (
This is so I can start the batch file a second time to change parameters without having to remember to stop the first instance of ffmpeg.
Many thanks for sharing, 73 John G7JTT
G7JTT
Retourner vers Other projects
