where is Noise Power measurement software? (NPM)
Messagede kb3pmr » Lun 21 Oct 2013 21:23
I have after several attempts with other versions had success with the tutioune1600 0.3a and it is running very well.
I am now seeking to down load and install the noise management and signal strength monitor to set the system up with the sun. Which is the best down load and should it be loaded in the same directory....tutioune1600?
Thanks in advance.
KB3pMR
kb3pmr
Re: after Tutioune1600 where is Noise Pwer measure software
Messagede F6DZP » Mar 22 Oct 2013 07:53
This software is not for the moment in the download section, but here, as beta version:
http://www.vivadatv.org/viewtopic.php?f=67&t=212
I had no bad return about it, it seems to work well, so I will finish the last version with measurement recording possibility and put it here.
You can put it in Tutioune Directory if you want.
Re: where is Noise Power measurement software? (NPM)
Messagede F6DZP » Dim 19 Jan 2014 09:15
new version in the download section
http://www.vivadatv.org/viewtopic.php?f=60&t=269
Messagede Sarahah » Mer 6 Sep 2017 05:54
I was also using tutioune1600 0.3a and was working fine for me. :)
Sarahah
Retourner vers Noise Power measurement software using TT S2-3200 or TT S2-1600 card
