abundant test and ts files
Messagede kb3pmr » Lun 10 Fév 2014 22:48
Can these just be deleted? I would like to clean up the directory.
bc
kb3pmr
Re: abundant test and ts files
Messagede F6DZP » Mer 12 Fév 2014 10:30
If you speak about .TS files you have created inside Tutioune Directory, you can delete them all.
You can also delete all TiouneData files.
Messagede kb3pmr » Mer 12 Fév 2014 10:34
Each time I run the system I get more .Text and .TS files in the directory. I would like to remove these if they are regenerated each time 2tune is ran. Is there any harm in deleting them?
kb3pmr
kb3pmr
Messagede F6DZP » Mer 12 Fév 2014 14:06
->you will get .ts files only if you press the RECORD button. If you don't press it you will see any new .ts file.
.ts files are the recording of TS received. It is used for analysing or to play it with VLC... or to remodulate it in your DATV modulator
- >you will get .txt files ( Tiounedata files) only if you press the SaveData button. If not, you will not see any new .txt file.
these txt files can be observed with TiouneData reader.
The only file Tutioune create by itself when starting is the little "Newdecod Mpeg2.grf" file that don't take place.
Jean Pierre F6DZp
