Tutioune3200 for TT S2-3200 - Last version
Messagede F6DZP » Mer 29 Jan 2014 13:42
Here you can download Tutioune3200 for TT S2-3200 PCI cards. -
install tutioune3200v0_2a_en.zip
(another version follow this - see next message)
Instructions can be find in the "read me" file.
what is new:
- We can now set audio level
- we can use any value for Offset ( example in the tutioune3200.ini file)
- we can record measurement data during a session and read/analyse them with TiouneData Reader.
- we can set in tutioune3200.ini if we want autoPID or not when Tutioune start.
Vous n’avez pas les permissions nécessaires pour voir les fichiers joints à ce message.
Re: Tutioune3200 for TT S2-3200 - NEW version
Messagede F6DZP » Jeu 30 Jan 2014 14:17
New version.
Just some change in UDP function to add the possibility to use pseudo UDPaddress 127.0.0.1 and more buffer to test big broadcast streams.
install tutioune3200v0_2b_en.zip
(but perhaps this version require more powerful PC ...? )
Jean Pierre F6DP
Messagede zg3409 » Mer 5 Mar 2014 18:27
Note there is a beta version for the International Space Station (ISS) here:
viewtopic.php?f=66&t=281&p=671
Here you can download specific beta version of Tutioune that has a button "ISS" that you must check when you receive HAMTV. This will add DVB tables that are not present in the transport stream.
zg3409
Messagede DJ2DS » Sam 28 Juin 2014 13:30
Hello
I have trouble with the Installation from Tutioune. When I start the Software, Norton 360 says that there is a "SONAR Heuristic 120" Virus.
The warning comes on all three files 3200v0_2a, 3200v0_2b and 3200v0_2bISS.
`73 Dirk DJ2DS
DJ2DS
Messagede F6DZP » Dim 6 Juil 2014 17:10
Very strange.You are the first user that tell me that.
I don't use Norton 360, so cannot test with it.
I will try other online antivirus.
Retourner vers TELECHARGEMENT / DOWNLOAD SECTION
