Tiny Spectrum Analyser (TSA) for TT S2-1600
Postby F6DZP » Thu 9 Jan 2014 11:47
You can download and install TSA v0.2.
TSA v0.2 01_2014.zip
tested under WIN7_32 and WIN7_64
You need to have installed before the SAA7146a driver( 32 bits or 64 bits version) same as Tutioune.
You can edit the TSA.ini file for giving your preferred presets.
You do not have the required permissions to view the files attached to this post.
Users browsing this forum: Google [Bot] and 2 guests
Return to TELECHARGEMENT / DOWNLOAD SECTION
