New version to check if all is fine with your PC, before using Tutioune.
CheckMatosV4_2.zip obsolete see next message
put files in Tutioune Directory.
If you want to read the TS file you must first install LAV directshow filters.
You can find them here:
http://forum.doom9.org/showthread.php?t=156191
By clicking on "Version 0.59: Installer (both x86/x64)" download and install file : LAVfilters-0.59.exe ( click right to run as Administrator under Win7)
this will allow to read TS files and give you many codecs: mpeg2, AC3 ...and give you a Splitter Source Directshow filter that allow to read a TS file.
now run "CheckMatos"
Home
