Flash Player Help
Postby No Spam » Sat 6 Jul 2019 21:13
Hi
I hope this is in the right section.
Whenever I try to watch any video on the TioneMonitor I always get the message "You need to upgrade your Flash Player"
But how ? What version does it need ? As far as I know it is up to date.
Many thanks
Dave
No Spam
Re: Flash Player Help
Postby F6DZP » Sun 7 Jul 2019 05:43
you need a Flash player plugging inside your navigator, not the independant Flash Player software
which navigator are you using?
some like Chrome doesn't allow Flash player to work I think.
try another.
I use FireFox. no problem with it.
Postby No Spam » Sun 7 Jul 2019 18:51
Hi
Yes I am using Chrome. I will try I.E
No Spam
Postby No Spam » Sun 7 Jul 2019 18:58
No luck with I.E either :-(
No Spam
Postby F6GWE » Wed 11 Sep 2019 09:58
No Spam wrote:Hi
Many thanks
Dave
Hello
IE and Chrome need you authorize Flash Player
click on left "vivadatv.org..........." (on IE its a padlock and exclamation point on Chrome) you will see a bar menu
F6GWE
Return to Réseau TiouneMonitor
