TiouneMonitor, on the air
Postby steinway » Sun 6 Oct 2013 15:32
What is the best time to check this. Seem whenever I check no one is ever on the Air. :(
Bob kb3pmr FN10sk
steinway
Re: TiouneMonitor, on the air
Postby F6DZP » Mon 7 Oct 2013 20:34
I don't know.
Sometime there are several TiouneMonitor working, sometime none.
and for the moment Google map has changed the API so we can no more see the litlle flags on the map that say where are Tioune stations.
You must look at the list and detect call sign that are green.
I have to make the flags coming back, but don't know when it will be repaired.
Postby F6DZP » Mon 7 Oct 2013 20:36
I let my own TiouneMonitor working for the night.
tutioune.php?om_id=F6DZP&station_id=1
Postby F6DZP » Mon 7 Oct 2013 20:40
There is also now this GB station:
tutioune.php?om_id=G8GTZ&station_id=1
Postby steinway » Wed 9 Oct 2013 18:37
Thank you, I did find one on the air the other day. There was no call sign being transmitted but what seemed to be only a grid square. Something like JN06DP. Would this be correct? Should the call sign be a part the screen data? Perhaps where the blabla is? He was transmitting only a photo of a stream.
I do have a question regarding the Vcam. I have found multi versions and companies from E2EVcam...this one is like $50.00 usd. or Vcam by softtronics...this one if a free down load. Guidance here please.
I have some difficulty getting on this site due to work time. Could you please respond to this Vcam question via. KB3PMR@gmail.com as well so I can move forward as quickly as possible.
Bob kb3pmr
steinway
Postby F6DZP » Wed 9 Oct 2013 20:14
you can find vcam here:
http://www.e2esoft.cn/vcam/
Return to Réseau TiouneMonitor
