Minitioune V09beta8.9 & V0.8
Postby G6VBJ » Sat 29 Jun 2019 21:47
I have down loaded Minitioune version 0.8 & V09beta8.9 onto my desktop and also extracted to my desk top. When I run either MiniTioune_V0.8s.exe (S/W version 0.8) or MiniTone_V0.9beta8_9.exe I get the same failure message. The message is;
Device already used, No Handle for the device, we quit.
I am running Windows 10 Pro 64bit version 1809. This is running on a Apple MAC which runs Windows 10 under Bootcamp
Anyone have any suggestions as to what I am doing wrong.
Thanks
Peter
G6VBJ
G6VBJ
Re: Minitioune V09beta8.9 & V0.8
Postby F6DZP » Sun 30 Jun 2019 04:54
First question : what do have when you use "TestMyMiniTiouner" software?
Could you show a capture of the text?
Postby G6VBJ » Sun 30 Jun 2019 08:28
This is the tuner that I am using;
https://boutique.r-e-f.org/kits-et-comp ... c-nim.html
purchased at HamRadio 2019 last weekend
I never get to a position where the software runs, this is the error message I receive as soon as i start the S/W;
Thanks
Peter
G6VBJ
Postby F6DZP » Mon 1 Jul 2019 04:36
Postby EA3UM » Mon 10 Feb 2020 19:28
Hello pierre
Coincidentally something similar happens to me.
After months of working perfectly, and after having made some changes to the computer (W7 32 bits), now with the Minitioune 0.9 beta 8_9 I get the error "Device already used, No Handle for the device, we quit". However, on the same computer I have W10 (64 bits) installed and the program starts perfectly.
I do not know what can be due.
Another question (and sorry):
I am launching the Minitioune Pro 2 and after looking for a dedicated software, I interpret that it is version 0.9 8_9 or some extended version. Is that so? Can you confirm it for me? or where appropriate can i download it?
Thank you
EA3UM
Magi
EA3UM
Return to autres logiciels
