V0.9 beta8_9
Postby on4bhm » Thu 22 Aug 2019 12:32
case:
i'm tuned to the beacon.
i give an UDP command to tune to other station.
my UDP stream keeps on giving the beacon... it doesn't switch to the newly tuned station.
although the new station is already locked and visible in the program. the UDP stream remains the beacon.
Is this reproducable? and a bug?
on4bhm
on4bhm
Re: V0.9 beta8_9
Postby F6DZP » Thu 22 Aug 2019 20:01
hello,
it is technically impossible or don't understand what you write
when you are tuned on a station the NIM cannot receive the TS from another freq.
The only thing that can arrive is that you continue to see/get part of ramaining data in the buffer from the precedent stream . but these data will be followed by the new stream.
how do you measure or know that??
impossible.
Re: V0.9 beta8_9
Postby on4bhm » Fri 23 Aug 2019 12:49
i thought so,
anyhow.... skip it.
another question: isn't it possible to get a udp message back when there is a lock and when the video is visible?
i need this trigger to reload my udp viewer, he doesn't restart when channel is switched. and the previous channel has stopped..... :(
on4bhm
on4bhm
Re: V0.9 beta8_9
Postby on4bhm » Fri 23 Aug 2019 13:06
one other remark:
Everytime i send a tuning command via udp, and the stations locks, the memory usage increases...
it's clearly visible.
on4bhm
on4bhm
Return to TUTIOUNE Logiciel de mesure et réception DVB-S en DATV
