Sound
Postby G8YTZ » Sun 9 Sep 2012 20:57
When using Tioune Video V0.5d I cannot get any sound, is this expected or have I a problem with the CODEC that I am using?
Card is the TechnoTrend, I must admit the software works very well indeed, running on Vista.
Best regards,
Justin G8YTZ
G8YTZ
Re: Sound
Postby G8YTZ » Tue 11 Sep 2012 15:57
I have solved the sound problem! The problem was to change the sampeling rate of the Sound Blaster card to 48kHz, down from 192kHz!
Justin
G8YTZ
Return to Les cartes PCI de réception DVB-S
